Z home with autolevel
I can create x and y Home but the arrows are blocked in repetier and I cannot create z home and my sensor NPN NO is not recognized . how to do, please?
the sensor does not stop when the light turns on . it is connected to z min.
the first M119 is open, the second the same, not triggered
i3 PRO C - Repetier - Marlin
i3 Pro C double extrudeur MK8 - carte GT2560 avec 5 A4988 - lit chauffant
Re: Z home with autolevel
Hi,qdshombre wrote:Hello,
Have you already tried this one?The endstop's settings are similar.
http://www.geeetech.com/forum/viewtopic ... 13&t=17042
TY for the answer.
I saw this post. now I installed a sensor, not a switch.
M119 is open before and after , no trigerred because the sensor is not recognized .
But voltage drop when I put something in front of the sensor.
Hi,qdshombre wrote:TY for the answer.
Sorry,you mean you didn't install the sensor before?What i think is,you can manually trigger the endstop one by one after installing the sensor and the endstop,cuz you said it can't be recognized.Also,you'd better check the connection of endstops.
BTW,you'd better finish the installation and test of your endstops before you start a test of your motors.
Good Luck
of course, the machine worked with a swith , now I installed a sensor.
With the sensor, I cannot reach z home . I must first declare the sensor plugged ''z min''. but I don't know how.(pins.h...)
I cannot reach Z home . I must first declare the sensor plugged Z min. But I don't know how.
I cannot reach z home . I must first declare the sensor plugged z min. But I don't know how.
Well,i think you can swap Z axis endstop's connector on the motherboard with X axis's or Y axis's and see if it works.Maybe your Z endstop is broken.qdshombre wrote:I cannot reach z home . I must first declare the sensor plugged z min. But I don't know how.
I plugged the 2 cables Y on Z min and the switch dont stop the bed on the Y axis.
