Hi, after fix some problems on this printer, now it can print +/-, but needs change some parameters on slicer...
I read all manual and I don't know how to print with both extruders. There's no video with a tutorial abou this...
I tried this:
1- Use slicer with geeetech settings to generate Gcode and saved it on SD card.
2- put SD card on printer.
3- Choosed template 1 and started print.
With this, the printer only print with "filament 0"... What I need to do more? Thank you
One more thing, someone can share here your slicer custom settings and results?
M201- How to print mix colors? And custom Repetier setiing?
Re: M201- How to print mix colors? And custom Repetier setii
There are a lot of details about the MIXER in 7.1&7.2 in the M201 User Manual,you can refer to it to make your mixer step by step.
As for what you said,the printer just worked with one filament,you can enter "template 1" to see what the filaments proportion is,i guess you set the filament "100%".Or you can check if you extruder 1 has a clogging.
all extruders works well, in repetier I choose extruder 1 or 2 and manually I can extrude each filament.
My problem is that, when I print, I choose template 1 for example, that I read that changes every 2mm, but nothing happens.
