Using Repetier when I try to set home position all axis bumps endstops and stops, this is not the same for the Z axis, that hit the endstop and push it for other 8-9mm. Also If I try to move the Z axis UP it cointinues to move DOWN, this happen after and before the home position calibration.
I checked several things: Motor Driver (0,8), ENDSTOP Plug and connection (It works fine, in fact when the extruder support bump the endstop I can see the codec of ENDSTOP OPEN/TRIGGERED on the software). I tried also to invert motor sense of turn, and they go, at the same way, UP without the possibility do go DOWN.
I can't understand what are other possible causes of this problem... I don't know If it's the software... I tried Repetier 1.6.0 and 1.6.2 and nothing changed. Help me please!
