Y Axis M10 threaded rod length
Suggy
Post by Suggy »
Hi all. Started to assemble my Pro B and I have used all the right parts.
M10 threaded rod 450mm
Smooth rod 390mm
Y plate connecting plate
M10 spring washers
M10 washers
M10 nuts
But when its assembled the 10mm threaded rod 10 is protrudes out the ends by, front 10mm and back 25mm.
I have double checked the rod sizes on both the M10 threaded rod and the smooth rid and both are correct.
Is this how it should be or is there an error in the build instructions and I should use the 410mm smooth rod?
Thanks for looking and any input you may offer
