A4988 card KO
cecemoto
A4988 card KO
Post by cecemoto »
Hello to all I'm new in the geeetech familly :D
I received my new Geeetech I3 Pro B 2 weeks ago and I finish the building this week-end. When I try to make it working The Y axis was some times shaking and other times works. :roll:
I thought that was the motor so I cross the connection with the X axis motor => after The X axis motor was shaking and the Y was working well
After I reconnect the motor on their right connectors and the Y axis start again shaking.
I discovered that if I touch the A4988 Stepper Motor Driver the Y axis was working normally but some times not.
I crossed the A4988 Stepper Motor Driver with the Z axis and after that the is was the Z axis who shakes.
I Tried a printing obviously it doesn't succeed.
For the expert in the forum does my diagnostic correct or do you have other Idea to find the origine of my issue ? :idea:
Thanks to all
Re: A4988 card KO
You can measure if the voltage between the potentiometer and GND was too low,and increase it if it was:
cecemoto
Re: A4988 card KO
Post by cecemoto »
thanks for this proposition of diagnostic. I'll verify this evening
cecemoto
Re: A4988 card KO
Post by cecemoto »
Hello, I tried to measure the voltage between the potentiometer and the ground. I got 0.78V I tried to modify the value to obtain 1V but it was difficult. Since the motor doesn't move any more. I tried to change the A4988 card with the motor of the X axis and the issue follow the card the X axis doesn't move and the Y axis does.
Do you have an other idea ?
if not I think that the card is over !
The printer never works, how could I received a spare parts .
Re: A4988 card KO
cecemoto wrote:Hello, I tried to measure the voltage between the potentiometer and the ground. I got 0.78V I tried to modify the value to obtain 1V but it was difficult. Since the motor doesn't move any more. I tried to change the A4988 card with the motor of the X axis and the issue follow the card the X axis doesn't move and the Y axis does.
Sounds like the A4988 on Y axis has some problems,you can ask your seller for a replacement.
cecemoto
Re: A4988 card KO
Post by cecemoto »
thanks a lot I'll do this
cecemoto
Re: A4988 card KO
Post by cecemoto »
Just to give a feed back, the card has been changed and now the printer works perfectly.
Thanks for your help
Re: A4988 card KO
Congratulations,and thanks for your updates.
