I attached an inductive sensor to my G2S pro. There was nowhere wonderful to put it however so it sticks out quite a bit further than the stock level sensor (which I don't have.) My offset as calculated by homing the printer, then moving it to 0,0,2mm and then putting a dime under it, then moving the level sensor over the dime is:
#define X_PROBE_OFFSET_FROM_EXTRUDER 48 // Probe on: -left +right
#define Y_PROBE_OFFSET_FROM_EXTRUDER -14 // Probe on: -front +behind
#define Z_PROBE_OFFSET_FROM_EXTRUDER -0.51 // -below (always!)
This is too far. The software does not want to compile with auto level turned on:
#error The X axis probing range is too small to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS
Is there some way to get auto level to work with the sensor in this position, or do I have to find some way to mount it closer? There is a mount on thingiverse which looks like it would move it closer, but not by very much.
Inductive leveling sensor on Delta G2S pro?
hyperlogos
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
