Page 1 of 2
3D Touch Sensor Issues
Posted: Wed Dec 14, 2016 5:14 pm
by Shane
I recently purchased a 3DTouch sensor and installed the unit however the device fails its self-test at power up. The pin is only ejected and retracted twice then starts blinking the error condition. I have done the calibration of the grub screw and led as per the video many times and it remains with the same fault. I have also checked the operation of the pin and it moves freely with no points of sticking. Finally I connect up an external 5V DC supply to rule out the main board (GT2560) but the fault remains. It is connected to a Geeetech i3 pro B as per the instructions. I now suspect that the unit may be faulty. Has anyone experienced issues getting the touch sensor to function?
Re: 3D Touch Sensor Issues
Posted: Wed Dec 14, 2016 5:47 pm
by Cup
Shane wrote:I recently purchased a 3DTouch sensor and installed the unit however the device fails its self-test at power up. The pin is only ejected and retracted twice then starts blinking the error condition. I have done the calibration of the grub screw and led as per the video many times and it remains with the same fault. I have also checked the operation of the pin and it moves freely with no points of sticking. Finally I connect up an external 5V DC supply to rule out the main board (GT2560) but the fault remains. It is connected to a Geeetech i3 pro B as per the instructions. I now suspect that the unit may be faulty. Has anyone experienced issues getting the touch sensor to function?
Did you read these two posts?I think you can find something useful:
http://www.geeetech.com/forum/viewtopic ... 27&t=18263
http://www.geeetech.com/forum/viewtopic ... 27&t=18371
And could you attach a video to show your test?
Posted: Wed Dec 14, 2016 9:12 pm
by Shane
Yeah I went through both those posts as part of my trouble shooting and they contain good information but neither of them seem to be able to help me solve my problem. I tried to attach a video but this site keeps stating the extension is not allowed (tried mp4, flv and wmv). how do I attach a video?
Posted: Thu Dec 15, 2016 11:56 am
by Cup
You can attach a Youtube link i guess.
Posted: Thu Dec 15, 2016 4:12 pm
by Shane
Below are the links to the videos;
In this one the power is applied to the unit, it should complete a power up test however it fails to operate correctly.
https://youtu.be/AkHzIY6X1EY
In this one I attempt to calibrate the grub screw but it ends up worse then when I started. I have done this test many times and the best it can get to is shown in the first video.
https://youtu.be/FT-w1xVLuSM
Posted: Fri Dec 16, 2016 10:45 am
by Cup
You can get the pin removed from the sensor,then check if the pin was bent or there's something else wrong with it(check if the black cap on the pin is a little loose).
- QQ图片20161212163314.jpg (41.38 KiB) Viewed 23065 times
Posted: Fri Dec 16, 2016 10:55 am
by Cup
Then you can send "M280 P0 S10" to check if the sensor works after sending "M280 P0 S160" to release the alarm(if the sensor is flashing).
Posted: Fri Dec 16, 2016 2:29 pm
by Shane
I removed the pin from the sensor and it looks good, its not bent or showing any signs of damage and the black rubber cap isn't lose and doesn't look to be damaged. I also looked for obstructions inside the plastic case that could jam the pin but their was nothing.
After I reassembled the unit, I sent it the "M280 P0 S160" command which released the alarm and stopped the unit flashing but when I sent it the "M280 P0 S10" it ejected the pin once and then returned to the error condition (blinking). I tried performing a calibration on the grub screw again and it still didn't function correctly (exhibits the same fault).
Posted: Sat Dec 17, 2016 4:59 pm
It's so weird...
Could you attach your wiring between the board and the sensor?
Posted: Sat Dec 17, 2016 7:03 pm
by Shane
Hi William,
Yeah I've been trying to figure this out for about 2 weeks or so.
Connection are as below, I ended up soldering the connections when it first didn't work to rule out a dodgy connection in the pins and plug. I suspect their is something wrong with the driver board on the inside of the unit.
