Looks like a good start at an easy to use printer host/slicer.
When I select a different printer in the config dialog, the selection keeps going back to the MeCreator 2 as soon as Apply or OK is pressed.
Edit: it works when I "Run as Administrator". I think access is being denied to the Geeetech folder in Programs(x86).
Can't select printer
Re: Can't select printer
Thanks for your report, we will check and fix this bug soon.Veenoh wrote:Looks like a good start at an easy to use printer host/slicer.
macinblack
I can't change too... please fix it
Hi,@macinblack
First run easy print as administrator,then try install it on other Disk not Disk C.
