Hi.
I have a G2S pro and a Rostock 301 and the command
G28 X0; Home X axis end-of-print causes the printed parts to be dragged into G2S PRO and into Rostock 301 as it executes X0 first.
gcode end
Re: gcode end
Hi,tuskman wrote:Hi.
Did you use Easy Print or Repetier Host?
I guess you add "G28 X0" in "End Gcode"?
Actually,we add "G28" command in "End Gcode" generally not "G28 X0" for Delta printer.
Re: gcode end
I use both and the bug is in easy print. At the end of the printout, it first makes X0 and then G28. I say it because it first goes to the x-axis and then goes home.
thanks.
thanks.
Re: gcode end
Thanks for your feedback,we'll check it soon.
Re: gcode end
Actually, the main problem is in the printer firmware, at least for the 301. Delta printers are supposed to ignore the x y and z flags in the G28 command. Geeetech tech support is aware of the problem and has said their engineers will fix it in the next release.
- Przepka1985
- Contact:
Re: gcode end
Use G27 P2bang wrote: Thu Jan 05, 2017 9:50 amHi,tuskman wrote:Hi.
Nozzle will get away from printed item.
Remove all movement co and like G1 from end gcode.
Leave turning heater and bed off, and fan up to you.
