Geeetech 3D Touch
SGRasmus
Geeetech 3D Touch
Post by SGRasmus »
Hi'
I have installed the 3D sensor as described, and all cables are in place. I have modified the firmware as described. But no succes!
The sensor just stay blinking in the middle of the printer. Every time I try to "take it home" it just go back in the middle and a
again a little bit higher on the Z-axis.
I have then downloaded the firmware from William in this site, but no go. Still goes in the middle and a litte bit higher. And I
can't even bring it down manual in the Repetier-Host. When it has gone up on the Z-axis, it stays there.
I have tried all the G-codes, but only one that is function is the "alarm of". And then after a while, it starts blinking again.
Anyone - William??!? - who could give a solving responce to this?
Best Regards to everyone.
_S
bang
Re: Geeetech 3D Touch
Post by bang »
Did you check this post?
viewtopic.php?f=27&t=18371
You need make sure the four testing code can make the right response before auto-bed-leveling.
SGRasmus
Post by SGRasmus »
Hi' again
I do not know, and I can't explain it, but! I pulled out the red wire (the power wire to the
sensor) when the printer was connected, and I put it back in place. And all of a sudden
the s... was working.
Sorry if I have made a fuzz out of nothing, but it is wierd, and this i3 Pro B is living
a life of its own. I wiss I could come up with a explenation, but.... nope.
So - printerlife goes on..... and so do mine...
B.R.
_S
