Access Denied trying to save Configuration.h file
mesamike
Post by mesamike »
I've upgraded to Lead Screws on my Aluminum Prusa.
Downloaded Arduino IDE from your Wiki page.
Downloaded Marlin from your Wiki page.
Sanguinololu shows up in the IDE and I see it on COM3
I change the printer to 62 and try to save it. I get "java.io.IOException: Access is denied".
I can't do anything with the Marlin files.
In your procedures it shows saving to "2560", why would I save it to that when I'm using Sanguinololu?
So I can't update the firmware.
I can't load the firmware.
Any suggestions?
Mike
mesamike
Re: Access Denied trying to save Configuration.h file
Post by mesamike »
I'm able to save the file now.
I uploaded it to the Sanguinololu. Successful
Now, when I connect Repeiter to the printer I get "FATAL ERROR".
15:49:08.915 : Error:0
15:49:08.915 : : Extruder switched off. MAXTEMP triggered !
15:49:08.946 : Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
15:49:09.946 : Error:No Line Number with checksum, Last Line: 0
15:49:09.946 : Error:Line Number is not Last Line Number+1, Last Line: 0
15:49:09.946 : Resend: 1
15:49:10.025 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
Mike
mesamike
Post by mesamike »
No more "Fatal Error".
I was able to upload the firmware and connect with Repeiter.
I went into manual mode. Tried to home all axis'
Stepper motors moved 1 mm. That's it.
Will not home.
I followed this link to update the firmware:
http://www.geeetech.com/wiki/index.php/ ... le_Burning
mesamike
Post by mesamike »
Please tell me where to find CURRENT UPDATED procedures for updating the firmware.
I followed this procedure:
This procedure is not correct.
NOW I"M BACK TO FATAL ERROR !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bang
Post by bang »
Did you get the right firmware for your printer from here?
viewtopic.php?f=20&t=17046
And refer to this post to upload it:
viewtopic.php?f=20&t=16433
And remember to use Arduino 1.0.1:
http://www.geeetech.com/wiki/images/a/a ... indows.zip
mesamike
Post by mesamike »
Everything works. Funny how following the procedures correctly seems to resolve problems.
The Lead Screws are a great upgrade. Smooth.
I did have one problem when installing the screws.
I had to file the screw hole on the upper left bracket to relieve binding issues.
I think that was what caused my original problems.
Mike
