I have finished the assembly of my Geeetech Acrylic i3 Pro B (my first 3D printer) and everything is working perfectly (axis movement, bed/extruder heating), except the extruder.
I'm not sure what's going on and I did a lot of searching , but I didn't see anyone having a problem exactly like mine.
The extruder extrudes balls. Literally. I've attached a picture. Click for a larger view.
I'm using a brand new roll of U3Print PLA Basic plus 1.75 mm. The filament just bubbles on the nozzle and drips down when big enough.
I've tried playing with the heating options - tried 180-220C, but without much difference.
Have I done something wrong with the configuration of the printer or is a part in the extruder/filament bad?
I'm running Repetier Host with Slic3r (imported the settings config.ini file, provided in the instruction manual).
Thanks!
