Repetier with Windows Vista
Fxg2012
Post by Fxg2012 »
I am new onbaord and I try to install Repetier 1.6.0 on my computer (quite old) using Windows Vista. I am not able to launch installation, eventhoug the repetier website says it is compatible.
Thanks for your help
Soadyheid
Re: Repetier with Windows Vista
Post by Soadyheid »
Have you got .NET framework 4.0 installed as per the prerequisites?
Prerequisites
Before you start with the installation, you should check if your computer meets the requirements. Currently available computers should have no problems at all. If you have an old computer running Windows XP you may have difficulties. The Host works on Windows XP and later and on Linux. If you have a Macintosh computer, check for the Repetier-Host Mac on this site. All you need is .NET framework 4.0 or a recent Mono installation, if you are running Linux. The only other requirement is a graphic card with OpenGL. For a good rendering performance OpenGL 1.5 or higher is needed. With lower versions you may have speed issues with live preview.
From Repetier software Install & Docs page. https://www.repetier.com/documentation/ ... iguration/
Play Bonny!
Soadyheid
