I then did a calibration of the 3DTouch according to the wiki, and got a Z axis value of -1.80. So I then put the -1.8 and the other values into configuration.h :
Code: Select all
#define MANUAL_X_HOME_POS -12.00
#define MANUAL_Y_HOME_POS 10.00
#define MANUAL_Z_HOME_POS -1.80Now, if I do a G28, I get the following results:
X: -12.00
Y: 10.00
Z: 5.00
Looking at the Positions in the Repetier (V2.0.1) "Manual Control" tab, I see:
X: -12.00
Y: 10.00
Z: -1.80
If I do an M851 it returns - Z Offset : 0.00
If I try to print, It starts extruding about 4-5mm above the bed.
What numbers should I put into configuration.h, and where?
Thanks,
Paul
