Mini square PCB heatbed for me creator - this board is the pefect  size  for one of my kit built printers. Could ay one tell me what type of female connector it needs?
Also what is the thermistor type on the pcb board ?
finally the pin out I'm guessing pins 1 and 6   are 12v and  gnd   pins 3,4 are +ve , grnd for the  thermistor  are pins 2 and 5 used?
cheers
						Mini square PCB heatbed for me creator questions
				Newopint95
Re: Mini square PCB heatbed for me creator questions
As far as I can tell the board is shipped without any leads or thermistor. So you can use any style.
it has a thermisator soldered in the   middle.
