Neither the hotbed or extruder heat up
I have been using my Prusa 13 A pro, occasionally, for about one year, with no problems. Today, when I set up to print, both the hotbed and the extruder would not heat up. Any help will be greatly appreciated.
Re: Neither the hotbed or extruder heat up
You need first check whether the hot bed and extruder line connection is good, especially with the board connection.
If above of all is ok,please refer to the following link:
Thanks William! It was a loose connection. Printing nicely, as I am writing this.
