I have just finished building the rostock 301 3D printer and am now configuring it.
I have ABS Filament and am trying to test the extruder, but it will not go above 220 Degrees. I have set it to go to 245 but it will get up to 222 and then drop to 218 and back to 222 degrees.
Doe sany one have any idea on how to get it to go hotter, Is there a setting in the software.
I have tried the pre heat ABS and still it will not get any hotter
Extruder wont go above 220
colin.eamens@c-eamens.wales
Re: Extruder wont go above 220
You should burning the new version firmware to unlock the limit of nozzle temperature
viewtopic.php?f=20&t=17046
Thanks very muckh William, I have upgraded the firmware as you suggested. it now goes over the 220 mark, now I can get on witht the rest of the calibration
Thanks again for your help
