EasyPrint 3d Crash - Regional settings
Michal M
Post by Michal M »
While slicing objects I'm always getting error on my PC - app crash.
I looked in event viewer and saw:
w System.Number.ParseDouble(System.String, System.Globalization.NumberStyles, System.Globalization.NumberFormatInfo)
w System.Convert.ToDouble(System.String)
w EasyPrint.view.CuraSlicer.GetProgressDetails(System.String)
w EasyPrint.view.CuraSlicer.ShowProgress(System.Object, System.Diagnostics.DataReceivedEventArgs)
w System.Diagnostics.Process.OutputReadNotifyUser(System.String)
w System.Diagnostics.AsyncStreamReader.FlushMessageQueue()
w System.Diagnostics.AsyncStreamReader.GetLinesFromStringBuilder()
w System.Diagnostics.AsyncStreamReader.ReadBuffer(System.IAsyncResult)
w System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
w System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
w System.IO.Stream+ReadWriteTask.System.Threading.Tasks.ITaskCompletionAction.Invoke(System.Threading.Tasks.Task)
w System.Threading.Tasks.Task.FinishContinuations()
w System.Threading.Tasks.Task.Finish(Boolean)
w System.Threading.Tasks.Task.ExecuteWithThreadLocal(System.Threading.Tasks.Task ByRef)
w System.Threading.Tasks.Task.ExecuteEntry(Boolean)
w System.Threading.ThreadPoolWorkQueue.Dispatch()
It made me thinking that there is a problem with regional settings (I'm in Poland so my decimal separator is , ).
Then run the same version on my VM with US regional settings - and works fine.
Re: EasyPrint 3d Crash - Regional settings
You should install the NET framework(3.5) correct
Michal M
Post by Michal M »
Nope - I told exactly whats the issue...
Just pass this to developers: use - https://msdn.microsoft.com/pl-pl/librar ... .110).aspx
Easy to test - changing regional settings of system to Polish = crash during slicing because of this line 'System.Convert.ToDouble(System.String)'
MichaelK
Post by MichaelK »
1. Close EasyPrint 3D
2 Find these path onto your pc: c:\user\(your_name)\AppData\Roaming\easyprint
Delete the path "easyprint" completely and restart EasyPrint 3D. You need to reconfigure your printer into EasyPrint 3D.
Take a stl-file and slice it again.
MichaelK wrote: Fri Mar 30, 2018 10:55 pm 1. Close EasyPrint 3D
You are correct!
Darkmatter1982
Post by Darkmatter1982 »
I had a problem related to the Italian Regional settings ( expecially for the decimal separator) and i solved it adding a new regional settings (English).
My problem was appear when i tried to modify values with decimal point...in that cases ,a value of "0.3" became automatically"3" and the program,obliviously,didn't work correctly.
This is only for people that have the same issue and for bug trace report.
Goodbye
P.S.
My O.S. is Windows7 sp1 x64 italian regional settings ( now is english UK)
i use Easyprint3D 1.2.3
Gingko
Post by Gingko »
Darkmatter1982 wrote: Tue Aug 21, 2018 6:45 pm Hello,
Goodbye
P.S.
Thanks for the feedback, we have reported it to our technicians.
