Problem with my z axis in my pro W
aradxc56
Post by aradxc56 »
i have recently bought a prusa I3 pro W, and after mounting it I tried yo calibrate it but the z axis when I send it to z=0 it goes just to an upper position, what can I do?(i am totally noob)
Re: Problem with my z axis in my pro W
Have you tried to refer the user manual?
You need to change the direction of the Z axis
The user manual show you how to.
aradxc56
Post by aradxc56 »
[quote=William post_id=83111 time=1520854863 user_id=51382]
[/quote]
problem solved, thx.
michaelf444
Post by michaelf444 »
do you have problem with your axis and you are worried I also worried about my assignment but my friend give me statistics assignment writer online for my assignments they help me in my assignment if ask them they will also help you in your axis.
kuznetsovarte
Post by kuznetsovarte »
Set the Z axis so the proximity sensor goes off with only a 'business card' between the bed and the hot end.
Since I've moved everything, the first thing to do is set any previous offsets to zero.
If the Z setting is not zero, set it to zero by typing in M212 Z0.
Official Website
