can connect to repetier but cant sand comands
If you have uploaded marlin to your gt2560 and try to connect it to repetier but you can't send command to the printer.To fix this you have to change the serial port to 0 in (configuration.h) in marlin and upload it to the gt2560 then it will work.:)
Re: can connect to repetier but cant sand comands
You need to set the correct baud rate
GT2560:250000
GT2560:250000
