hi
I just install Easyprint 3D, and the A30 isnt in the list of printer.
Where can i find the driver for A30 (A30.ini and A30) for this software ?
Driver for A30 with easyprint 3D sotfware
Re: Driver for A30 with easyprint 3D sotfware
have you tried to upgrade the EasyPrint to version 1.1.7?
The A30 is available in EasyPrint3D Version 1.1.7 and the latest Firmware update is there available, too.
[attachment=0]EasyPrint3D-1.1.7.png[/attachment]
- EasyPrint3D-1.1.7.png (51.2 KiB) Viewed 14993 times
BenjiBegood
Yes, I do it and I have the A30 driver.
But the 1.1.7 can't slice !! the software shutdown and exit when i try to run the slicer. so I can't use this version ;-(((
I found something that may help u
Easyprint--How to add your printer(If the software does not have your printer in default):
viewtopic.php?f=45&t=60680
Easyprint 3D slice problem.
viewtopic.php?f=44&t=60705
You can find the printer listing inside the add hardware and software option. There you will see the name of the printer as just click their online essay writing service you will see the built-in options of the printers in it.
