If someone else wants to experiment with Slic3r, here is my setting file. I often tweak something for each print, but this is pretty good base configuration.
Usage:
1) Unzip (this forum didn't allow me to attach .ini file)
2) Import MeCreator2.ini to Slic3r PE:
File -> Load Config Bundle
Made with this version:
https://github.com/prusa3d/Slic3r/relea ... ion_1.39.2
*Updated v2:
-Correct g-code to turn off bed after print. It was originally ok, but I must had made mistake during cleanup before sharing.
-Support settings that should generate removable supports, if enabled.
MeCreator2 for Slic3r Prusa Edition
- MeCreator2_v2.zip
- (1.75 KiB) Downloaded 726 times
Re: MeCreator2 for Slic3r Prusa Edition
Thank you for sharing! :D
I updated the settings to include good supports (if enabled) and to turn off bed after print (I had accidently changed wrong gcode).
Because it is opening post in topic, it went again under review. So please wait if it is not visible.
