nossle only crashes
That Gamer 64
nossle only crashes
So, I bought a G2s printer around january and i built it it is all correct. Today I finaly figured out the coding part of it. However at the begining of every print the nosle crashes into the bed and wreaks my tape. So does anyone have any idea where I could be going wrong.
dohabandit
Re: nossle only crashes
You have to adjust the bed height setting very precisely. Mine is around 196.01.
The way you do this is to home the print head and then very carefully bring it down using manual movement controls until a piece of paper just barely slides out from the extruder tip. Then look at the height setting and record that number. You then place that into the Marlin firmware that you compile as well as the printer settings in Repetier.
