E180 Firmware Upgrade
BennyBoyW
Post by BennyBoyW »
Hi All
Just got an E180 to see what it's like.
Having a problem with the firmware upgrade.
I downloaded latest version of EasyPrint and checked the Firmware version on the printer - it was old so I went for an update.
It's now stuck on "Updating LCD and has been for about an hour with no progress.
Any suggestions ?
Ben
discopants9
Re: E180 Firmware Upgrade
Post by discopants9 »
Got the same issue today, did yours go ok in the end
discopants9
did you find a solution to this as I am having the same issues now
Alex-w
Post by Alex-w »
What's the version of easyprint you downloaded?(If you want the details about the version, please review my instruction showing in Bug report)
You also can choose the smartto tools for your upgrading(https://github.com/Geeetech3D/Smartto-E ... ster/tools)
PM me if you have any questions about these softwares
@discopants9 @BennyBoyW
BennyBoyW
Post by BennyBoyW »
discopants9 wrote: Fri Jul 13, 2018 11:28 pm Got the same issue today, did yours go ok in the end
Still working on it - I'll post if I get to the bottom of it
BennyBoyW
Post by BennyBoyW »
sean wrote: Sat Jul 14, 2018 2:34 pm What's the version of easyprint you downloaded?(If you want the details about the version, please review my instruction showing in Bug report)
Version 1.2.0
I will try out your link to see if I get it sorted out
BennyBoyW
Post by BennyBoyW »
@discopants9
I extracted the toolkit straight to C:\ so it went into a folder called Toolkits
I also made sure the SD card was in the back of the printer
The Toolkit now runs fine
@sean
I ran the toolkit fine and it seemed to upgrade the firmware to 1.35.56
However, then I did an upgrade on the LCD too. The LCD said "Firmware upgrade" and after a while, the printer rebooted.
When it came back, the LCD was completely unresponsive when you pushed the on-screen buttons
I turned the printer off and on again and it's still completely unresponsive to touch
Any ideas ?
BennyBoyW
Post by BennyBoyW »
Hold on - sorted it.
The unresponsive screen was due to the screen not being calibrated
I pressed randomly around and started getting into the menus
With a bit of luck, I found the right menu for screen calibration and managed to work out where it thought the button was
When I recalibrated my screen, the printer menus now work fine and the printer is reporting the correct firmware version
So I'm back in business :D
Now to work out why my Y axis is not moving correctly lol
Alex-w
Post by Alex-w »
BennyBoyW wrote: Sun Jul 15, 2018 8:10 pm Hold on - sorted it.
:lol: Good news.
BennyBoyW
Post by BennyBoyW »
Thanks for all the help guys :)
