Page 1 of 2
Print quality on i3 pro W
Posted: Mon Aug 06, 2018 11:52 pm
by Derekchong
Can someone help on the print quality? The print on external wall layer have lots of gaps. Im using a 0.3mm nozzle. Does changing the nozzle to 0.4mm help? How to improve the print?
I have attache a photogrpahs of the print.
Re: Print quality on i3 pro W
Posted: Tue Aug 07, 2018 1:30 pm
by _kaktus_
But a beautiful printout. I would like to be able to do something like this. :D
I understand that you are not satisfied with the result achieved because you expected something completely different.
This may be due to insufficient filament flow.
To diagnose a problem, I have a few questions:
  • 1. Have you performed any extruder calibration?
  • 2. Can I hear an extruder click during the printing process?
  • 3. Have you calibrated the mechanism in the X, Y, Z axes?
Posted: Wed Aug 08, 2018 8:17 am
by Derekchong
I have calibrated the extruder. No clicking sound during the print. Do i need to calibrate the x and y axis? Seems fine to me.
Posted: Wed Aug 08, 2018 2:16 pm
by _kaktus_
What kind of filament you use. What temperature have you set on the head?
Maybe it is worth to increase the temperature by 5℃ and test it?
Calibration of the axis is not mandatory, but it is worth to go through this process. ;)
Posted: Wed Aug 08, 2018 5:47 pm
by Derekchong
Im using ABS filament. 1.75mm. I have tried raised the temperature but seems it make no different. The temperature im using was 235. Increase it to 240 make no different.
Posted: Thu Aug 09, 2018 2:31 am
by Derekchong
I calibrated the z axes and the quality it improved a lot more!!! Thanks for the advice.
But now im hearing clicking sound from the extruder on some part of the print. I suspect the layer and nozzle could be too near. Any suggestion?
See my print.
Posted: Thu Aug 09, 2018 3:26 am
by _kaktus_
Hi :mrgreen:
I also use the ABS filament.
But I set the head temperature at 250℃.
What is your filament brand?
Posted: Thu Aug 09, 2018 1:54 pm
by _kaktus_
Derekchong wrote: Thu Aug 09, 2018 2:31 am I calibrated the z axes and the quality it improved a lot more!!! Thanks for the advice.
Derekchong wrote: Thu Aug 09, 2018 2:31 am But now im hearing clicking sound from the extruder on some part of the print. I suspect the layer and nozzle could be too near. Any suggestion?
See my print.
The printout shows that one page is more pressed against the work table.
This may indicate that the work table is not level enough.
I expect that when the printer was doing that part of the printing, one could hear a click in the extruder.
You may want to try applying washer to the spring into extruder to increase its pressure.
Posted: Thu Aug 09, 2018 7:38 pm
by Derekchong
I will try to put a shim in the spring as suggested. What do u mean my work table is not level? Is my print bed not level that lead to the clicking sound? :roll:
Posted: Fri Aug 10, 2018 12:14 pm
by _kaktus_
work table = heat bed
I mean that the levelling procedure has to be done very precisely. As good as you can.
