Cannot print
RAO003
Cannot print
Post by RAO003 »
Re: Cannot print
You'd better check the PSU output voltage normal or not(12V)
It seems the PSU doesn't work.
axman
Re: Cannot print
Post by axman »
Does the control panel light up? If so, can you control the printer with it? You should be able to do that even with the computer disconnected.
Re: Cannot print
:mrgreen:
axman - when the printer is properly built and powered on, the LEDs on the controller board should light up.
