Geeetech A30 and Cura
MarkFish54
Post by MarkFish54 »
Does any one use Cura with the A30? If so what version ?
I am using 3.4.1 and unable to connect. The controller continues to reboot trying to connect.....
Thanks for ant help
Gingko
Re: Geeetech A30 and Cura
Post by Gingko »
Please try the Cura version of 15.04.6.
MarkFish54
Thank you for your reply.
Have you tried Cura 15.04.6 with the A30 ? and does it work? When I use Cura 15.04.6 the printer connects and then does nothing. I do have the latest firmware. I've tried your Easy Print and it does the same thing as Cura 15.04.6 "connects and then does nothing"
Thank you
Admin
Post by Admin »
Try to set the baud rate to 115200 then test it
MarkFish54
Thank you got it working...
