i3 Aluminium with Sanguinololu and Marlin V.1.1.9 - Help needed
I3dee
Post by I3dee »
Hi together,
I have just assembled a Geeetech Prusa i3 Aluminium with Sanguinololu board and it is running well now.
However I would like to update the firmware to the new Marlin V1.1.9 and have questions about this.
Today the printer uses this firmware, provided by Geeetech:
"for the upgraded kit using lead screw
Plusa_I3_A_sanguinololu(for the upgraded kit using lead screw).zip
(242.47 KiB) Downloaded 2563 times"
It seems to be quite old version as the configuration files differ much from those of the Version 1.1.9.
Marlin has example configurations for Geeetech printers with GT 2560 boards and for unnamed printers with sanguinololu board but not the combination of both.
Does anybody have a working set of configuration files for Marlin 1.1.9 and i3 Aluminium with Sanguinololu board?
Cheers
Bob
JohnDeere630
Re: i3 Aluminium with Sanguinololu and Marlin V.1.1.9 - Help needed
Post by JohnDeere630 »
I couldn't get anywhere flashing firmware on the sanguinololu board, so I replaced it with the GT2560 board.
Meister_Knobi
Post by Meister_Knobi »
I have flashed sucsessfully multiple times, but sadly with very inkonsistant results.
Im Also very interested in an config for an Uptodate Marlin.
JohnDeere630 wrote: Fri Sep 28, 2018 5:09 am I couldn't get anywhere flashing firmware on the sanguinololu board, so I replaced it with the GT2560 board.
When you have a working kinda Up To date Marlin FW, even for a GT2560, it would be nice if you could share it with us.
JohnDeere630
Meister_Knobi wrote: Tue Oct 09, 2018 3:48 am
Sorry, I don't check the forum as often as I should. I am attaching a copy of the 1.1.8 Marlin FW configured to work with my machine. It has a BL-Touch bed leveler, a filament sensor using the sensor pin for the Y max, and has the REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER enabled in Configuration.h
Hope this helps....
Marlin-1.1.8_GT2560-RevA+.zip
(2.57 MiB) Downloaded 812 times
