Problem with starting printing.
Fred_75
Post by Fred_75 »
Hello!
I have another problem with Anet A8. With the connection problems did not arise, the table normally moves with arrows. But I could not print anything. On one model comes the matter before the table warms up with the extruder, and then the "printing" sign hangs and nothing happens, on the other model even before the heating does not reach. The third model heated the table and extruded, the home position was displayed, the head moved to the center of the table ... and that's it. The inscription "printing" is on, but nothing happens. Files from the internal drive on the printer can be seen, but they do not print at all, for a few seconds the word "printing" lights up and goes out. The port speed is set, as on the printer, 115200. Also changed the cable to a shorter one. Did not help. What could be the problem?
Re: Problem with starting printing.
Hi, You can try to print the sd card test file that came with your printer.
If you still can't print, you can provide a specific video.
:mrgreen:
If you are using the WiFi Box, familiarize yourself with the manual. Pay attention to the behaviour of the LEDs during the start-up and operation of the module.
You can describe the state of the controls here.
