A10 Part cooling fan FIXED!!!! Thanks to combat341
This needs to be a sticky!!!!!
Kudos to combat341 for this
I thought that this needed to be a separate thread, rather buried in a post.
I did this and it works.
https://imgur.com/a/uPrCTsK
Thanks again combat341!!!!
AFewSkroosLoose
Re: A10 Part cooling fan FIXED!!!! Thanks to combat341
Agree! Many thanks.
mathiaskahn
Hello
Same problem with my new A10, with GT2560 v3.0 mainboard.
The extruder fan in not spinning, event at max (255) power.
I tested the mentioned solution with FAN_SOFT_PWM does not work.
The JP2 jumper does not seem to exist on that board (or I was not able to locate it).
Any idea ?
thanks,
Any idea ?
thanks,
mathiaskahn
Found same report here : https://www.geeetech.com/forum/viewtopic.php?t=61895
But proposed solution "play with the cables" like : https://www.youtube.com/watch?v=J8xEsue_Xa8
==> does not work"
==> does not work"
I look forward to fresh updates and will share this website with my Facebook group!
McAfee programming gives the digital security services to ensure your hardware information.
Install mcafee from mcafee.com/activate |
What is Malware
How do I Recover McAfee account ?
Use McAfee Antivirus Plus on your computer.
Why McAfee Internet Security is important?
What is Malware
McAfee is quick and easy to install. Install mcafee from www.mcafee.com/activate
Keep yourself secure with McAfee security .
McAfee activate on your computer.
How to Uninstall or disable McAfee WebAdvisor ?
What is McAfee Safe Connect VPN ?
How to login to McAfee account ?
How to know when does my McAfee Subscription Expire ?
McAfee programming gives the digital security services to ensure your hardware information.Install mcafee from
mcafee.com/activate
McAfee Mobile Security
update McAfee antivirus
mcafee.com/activate
travissmith39
- Contact:
ij.start canon
ij.start.canon is a platform for getting the canon printer driver . You can easily download the driver according to your model as ij.start canon is designed with a user-friendly interface. ij.start.canon , Https //ij.start.cannon . Canon IJ Network Tool is a toolkit software with the options to keep a check on most of your Canon printer network settings and adjust them according to your requirements.
