Hi all,
After reinstall of Marlin firmware (in an year it's the 20th times) via arduino 1.0.1 now I have a strange message on LCD
Instead the sentence "I3 Pro W" as ever now I have this one "IP 192.168.78.1".
I have not ethernet nor wifi module ... anyone can explain me what's happening?
The firmware has been downloaded from this forum in firmware section as ProW without LCD touch (in the zip file there is a strange chars dir).
If the system has assigned an IP to the USB/serial port where can I change this address?
Then also with 3D printing software (every type from repetier to easy print and so on) only bed and extruder warmer works but no motion from stepper
How can I reset the board (the button on it don't works fine ... nothing happens)
Any type of help (also a very little one) is appreciated
Thank you and a big halo from Italy
I3 Pro W
AntonioChiapponi
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
