hi,
after some years I decided to use again my Geeetech i3.
In the meantime I moved to windows 10 pro 64 bit.
I updated Repetier Host to latest version and connected my Geeetech i3.
The manual controls work OK , I can move the axis and heat the extruders.
The great problem is that it doesn't start printing at all.
I tried all 3 slicers without results.
I hope you can help me.
Geeetech i3 doesn't print with windows 10
Re: Geeetech i3 doesn't print with windows 10
A very interesting problem.
It seems that if manual control works, printing should also work ...
Have you tried to deactivate your Windows firewall for a while for a test
