3D touch sensor & A10
lvlacleod
Post by lvlacleod »
Newbie here. I've read and read through the forums and am still sratching my head.
I have just purchased an A10 and a 3d touch sensor. Wiring it I am fine with. Could some kind soul talk me through firmware update process please?
What software I will need, is there a pre-built firmware, if not, what do I need to change in the existing firmware and anything else I might need to know.
Thanks in advance,
lvlacleod
Re: 3D touch sensor & A10
:mrgreen:
You need to read the forum more carefully a moment before you krismcewan
wrote a great tutorial:
viewtopic.php?f=91&t=61618#p86425
:D
lvlacleod
Post by lvlacleod »
I read that but assumed because it was for A10M it would be different to the A10?
You are right. :D
The firmware will be different.
My omission. :roll:
Wolle82
Post by Wolle82 »
The wireing is defferent too. The A10 has no connector for the sensor at its hotend.
lvlacleod
Post by lvlacleod »
Yeah All connected to main board. I don't have a problem with the wiring and I'm a web and graphic designer (amongst other things :D ) so working with code isn't a problem it's just what code I need or if there is already a firmware built with the sensor settings. I can't find one so I am guessing it's writing some code.
Wolle82
Post by Wolle82 »
Perhaps all U need is here:
https://www.antclabs.com/bltouch
karuc
Post by karuc »
The touch sensor has some parathion to read that was on it this has data to get the artist that will qualify to get generate. The Board of the index has formation to read that has languagetool with the parties to make acceleration to make replies along with the acts on it.
followerscanada
followers canada
Post by followerscanada »
Geeetech Pro B i3 3D printer is designed and manufactured by Shenzhen Geeetech Co., Ltd, an international company whose commitment is to provide high ...by epicfollowerscanada
followerscanada
Buy followers canada
Buy GEEETECH A10 3D Printer Aluminum Prusa I3 Half Assembled DIY Kit with Print Size 220×220×260mm, OPEN SOURCE GT2560 control board at Amazon ...by buyfollowerscanada
