the hot-end of my extruder mk8 is no longer able to extrude properly
merlinorn
Post by merlinorn »
I have a problem ... the hot-end of my extruder mk8 is no longer able to extrude properly, I continue problems from hitch, which according to what I have tried do not come from the nozzle blocked but from the throat ... that is, inside the screw where the thread inside the heater, it does not slip any better, what could it be, what should I do? Can you clean? If so how? Or do I have to change it? Thank you
Re: the hot-end of my extruder mk8 is no longer able to extrude properly
:mrgreen:
You've probably got a blockage in this part.
To remove it you will have to disassemble everything.
