Remarks on configuring the Geeetech A10 in Cura.
emaren
Post by emaren »
I am not sure that the following two lines are useful in the Start G-code section.
Code: Select all
M109 S200;Heating nozzle
M190 S60;Heating bed
This appears to override Nozzle and Bed temp to 200/60 that are taken from Filament or Custom profiles.
Commenting them out, or zapping them entirely returns control of temps to Cura.
Re: How to add the printer Geeetech A10 to Cura
:mrgreen:
Temperatures are entered permanently. This is not the best solution.
Below you have a piece of script with parameters for two extruders. You can try it out.
Code: Select all
; Wait for all used extruders to reach temperature
{IF_EXT0}M109 T0 S{TEMP0}
{IF_EXT1}M109 T1 S{TEMP1}
:D
