3d wifi module on E180
hi, i have the geeetech e180 and the external wifi module, i cant connect the module to the printer, i connected both together and the module with my phone, but the printer does not do anything, what should i do?
Re: 3d wifi module on E180
Try to present in a more descriptive way which steps you have taken.
Write which version of the module you are using, and provide the application version number.
Have you tried to set the correct baud rate for it?
