Hello, with e180 normally you can set up a lot of standard parameters with any kind of software included easyprint, but for setting up stepping motor and extruder and other special values, you must use smarttoo motor software, but many times it crashes or it doesn't recognize other values, is it possible to use different software or do you have any suggestion for tipical problem of printing: here some example
the circle in printing are not precise but oval or elliptical
the printing extrusion is too much and you get the "web effect"
the printing extrusion is too much and you get the lines too much visible or blowing out from the printed object
the y or x axes do some strange sound when it moves fast it is like it jump
the hpid is not well settled
the printing bed value are incorrect
how to install correctly touch sensor autolevelling
if you can answere to one of this situation please help
best regards to all!
How to complete set up e180
ivanmemento
Return to “Geeetech E180 Mini”
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
