My new Geeetech A10 is not working correctly.
I can level it correctly and everything seems to work well but when it goes to print it hangs, the led screen goes blank and stops working.
The same thing happens with a temperature test of the hotbed. I think the problem must be related to the feeding of the warm bed.
Two videos with the issues. One trying to print and the other trying to heat the bed.
https://drive.google.com/file/d/1Eee-WT ... sp=sharing
https://drive.google.com/file/d/17yquYc ... sp=sharing
What I can do?
Thank you in advance.
A10 hangs when printing or heating the bed
Re: A10 hangs when printing or heating the bed
Solved.
The clips holding the print surface to the heat bed was creating a short circuit.
Applause for working independently and solving the problem
