Pro W Z axis problem
So every time I auto home, the z axis goes to a completely different position. When I try to home just the Z axis, it’s raises it by 2.2mm each time I press it. I’m fairly positive that the issue is firmware related but each time I try and update it or go to an older version I get different results. Any help on what I’ve done wrong?
Re: Pro W Z axis problem
hi there,
first download arduino 1.0.1
http://www.geeetech.com/forum/viewtopic ... 13&t=17181
than the firmware (number 13)
http://www.geeetech.com/forum/viewtopic ... 10&t=17046
you have to open the firmware from arduino 1.0.1 and load it on the printer.
hope the links will help you.
Starbucks Coffee
Which version from #13 is best to use.
