When the printer starts it seems like it is testing ok, then this below when I do the aut bed leveling.
Also the Z only move up, then the probe puches down and up, waits and the raises again.....
Code: Select all
12:22:20.024 : Error:STOP called because of BLTouch error - restart with M999
12:22:20.024 : Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
12:22:26.148 : Error:STOP called because of BLTouch error - restart with M999
12:22:28.842 : X:162.00 Y:125.00 Z:10.50 E:0.00 Count X:13009 Y:10100 Z:4200
12:22:39.703 : Error:STOP called because of BLTouch error - restart with M999
12:22:40.622 : Error:Probing failed
12:22:40.622 : X:152.00 Y:20.00 Z:25.43 E:0.00 Count X:12206 Y:1616 Z:10172Code: Select all
12:31:14.598 : N20 M999*24
12:31:14.598 : N1 M110*34
12:31:14.614 : Resend: 2
12:31:15.591 : N1 M110*34
12:31:17.306 : N2 M999*40
12:31:17.306 : N1 M110*34
12:31:17.306 : Resend: 3
12:31:17.322 : Error:Line Number is not Last Line Number+1, Last Line: 2
12:31:17.322 : Resend: 3ps. I have to 3D touch(s) and both does the same.
thanks all
