3D Touch installation on a Zonestar P802QR2
Posted: Sun Jan 06, 2019 10:01 am
Hi there! I want to share with everyone interested how I succesfully installed the 3D Touch sensor to a Zonestar P802QR2 with a ZRIB V3.1 board. (Zonestar is selling a 3D touch sensor on Aliexpress focussing on the ZRIB V5.2 but beside the pin's used this information is valueable anyway) I have been doing research for some days before I decided to buy a 3D Touch sensor from Geeetech and after that I suspected I could make it work. To be honest this is not a simple plug and play setup but it seems good to share this with the world.
So my setup before the installation of the 3D touch sensor was:
1. Get a 3D Touch sensor from Geeetech
2. Print a mount for the 3D Touch sensor that is compatible with the Zonestar 3d Touch sensor
This actually can be found on the www.zonestar3d.com website. Url: https://drive.google.com/file/d/1xtvHDd ... sp=sharing. See picture how to place this mount.
3. After confirmation the mount fitted I installed the 3D Touch sensor without connecting it
4. Extend the 3D Touch cables by using jumper/dupont cables female / female at least 70cm long. You need 5 cables, 3 for the servo and 2 for the Z- cable from the 3D Touch sensor. The other parts are in the package to install it.
4. Detach the existing Z- plug from the board, if you have the Auto level sensor (the blue proximity sensor sold with this 3d printer or as option) remove this also
5. Attach the white and black cables from the 3d touch to the board on the Z- interface (see wiring picture)
6. Attach the servo cables from the 3d touch to the board on the AUX1 interface (see wiring picture)
7. Zonestar switched from Repetier to Marlin in august 2018 and luckily it supports BLTOUCH/3DTOUCH. So the firmware must be updated and the only option for this is compiling the firmware yourself and upload it to the board
8. Download the firmware from https://drive.google.com/file/d/12pXbT8 ... sp=sharing if you need help how to use ardiuno firmware updates see https://drive.google.com/file/d/0B9Z1Db ... sp=sharing
9. When the firmware is extracted we need to make changes to make it work for the P802QR2, here is the list of changes:
9.1 config.h:
9.2 config.h: find rule, here are the default settings for this printer and we need to make some adjustmens
9.2 config.h: within the part, change:
9.2.1 needs to be changed to -20 (to center the 1st nozzle to the center of the bed)
9.2.2 needs to be changed to -3 (to center the 1st nozzle to the center of the bed)
9.2.3 (this needs to be added because the home axis are making the 3d Touch sensor move outside the bed and it fails and will crash your printer if not set!)
9.2.4 (this needs to be added to make the firmware know it has bltouch/3dtouch support)
9.2.5 (this needs to be added to let the firmware know the X offset between the 3dtouch probe and the nozzle's is 35 mm)
9.2.60 (this needs to be added to let the firmware know the Y offset between the 3dtouch sensor and the probe is 0 mm)
9.2.7 (this needs to be added to let the firmware know the Z- sensor is replaced with a 3d touch sensor
9.3 pins_ZRIB.h needs one adjustment as well, look for the line #if defined(IS_ZRIB_V5)
9.3.1(this line is normally set to 42, but the ZRIB 3.1 board has D20 as PIN for the servo, see wiring picture)
10. Compile and upload the software to the board. (attach the USB to the PC and set the correct driver and COM port, see www.zonestar3d.com downloads for details, there are instructions somewhere on the site)
11. After the firmware update is succesfull the Z offset should be adjusted. I followed the guide from https://www.youtube.com/watch?v=y_1Kg45APko (my Z offset was -2.80)
12. Make a test by home all (If you're not confident keep close to the power plug and shut it down if a clash is coming)
13. Using any tool that can send Gcode to the printer (ardiuno terminal monitor or pronterface) send a G28 and then a G29, it should home and level.
14. If all above steps are succesfull make you're first print
15. Enjoy your new configuration!
Hope this helps anyone going trough the same process!
- Stock Zonestar P802QR2
- ZRIB 3.1 board
- Auto level sensor (the blue proximity sensor sold with this 3d printer or as option)
- Stock firmware that was based on Repetier
- ZRIB 3.1 board
- 3D touch level sensor (from Geeetech)
- Firmware of Marlin 1.8
- Use the Z+ connections for the servo (they do not provide enough power for the 3dtouch sensor and it fails to stow)
9.1 config.h:
Code: Select all
#define MODEL_NUMBER P802QR2_5KEYCode: Select all
#elif (MODEL_NUMBER == P802QR2_5KEY)9.2 config.h: within the
Code: Select all
#elif (MODEL_NUMBER == P802QR2_5KEY)9.2.1
Code: Select all
#define X_MIN_POS -109.2.2
Code: Select all
#define Y_MIN_POS -59.2.3
Code: Select all
#define Z_SAFE_HOMING9.2.4
Code: Select all
#define BLTOUCH 9.2.5
Code: Select all
#define X_PROBE_OFFSET_FROM_EXTRUDER 359.2.6
Code: Select all
#define Y_PROBE_OFFSET_FROM_EXTRUDER 9.2.7
Code: Select all
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN9.3 pins_ZRIB.h needs one adjustment as well, look for the line #if defined(IS_ZRIB_V5)
9.3.1
Code: Select all
#define SERVO0_PIN 20 //XS1(AUX3) Pin1 10. Compile and upload the software to the board. (attach the USB to the PC and set the correct driver and COM port, see www.zonestar3d.com downloads for details, there are instructions somewhere on the site)
