3d touch help a10m
casimir24
3d touch help a10m
Post by casimir24 »
I can't configure the 3d touch with my a10m.
then test the video tutorial but my head still fits on the set
a person could give a version of a tutorial from zero
kind regards
casimir24
Re: 3d touch help a10m
Post by casimir24 »
after following this tutorial I find myself in printing with a z- 90 and the 3d touch is blocked
https://www.youtube.com/watch?v=_RtsZDbR2po
casimir24
Post by casimir24 »
can you show me how to do it?
kind regards
ogzer707
Post by ogzer707 »
There’s two z offsets? Or are you talking about the one written in marlin Configuration.h. do you zero that out then just use lcd?? I need help just like this guy
Geeetech A10m
ogzer707
Post by ogzer707 »
So i watched your video. thank you. first thing i did was unplug and remove my z axis endstop. then i follow your offset directions and end up with an offset of -7.69...i dunno why so high. i used to have it working at -1.932. now its really hi off the bed at zero. and to bring it down to paper height like your video it comes out to-7.69. then i follow your steps and g28 then g29 and this thing wants to go through the bed. what gives. and im on Marlin 1.1.8 for A10M - BLtouch firmware. when i install your latest 2.0 build it doesnt auto home. it crashes to right sideand of x axis. the lcd display shows question marks for all three axis as well X?.? Y?.? Z?.?
my physical z offsets are x -37 y-0 z-1.016
-37 measured with caliper from center of nozzle to center of bltouch tip
-1.016 is measured under my bltouch tip with spark plug gap measure @.040"=1.016mm
Geeetech A10m
ogzer707
Post by ogzer707 »
Ok. I will build 2.0 correct this time. I did download Arduino 1.8.8 to upload it to printer. I tried to use the Configuration.h. for my printer but I’ll spend more time on the next try. And thank you for the great advice of no other running applications while uploading. After reflashing 1.18 with my x-37 and z -1.016 written in marlin z probe offsets, my offset is now way more acceptable looking number down to -3.09.only problems having now is printing temps as my prints now curl up after time. Thanks again Vert. Your the man
Geeetech A10m
