E180 Extrusion Problems
hassan777
Post by hassan777 »
Hello everyone,
I got Geeetech E180 Mini 3D printer and suddenly it prints everything like a sponge (Easy to crash). I look after every possible solution around the internet. I even changed the nozzle. I cleaned the machine. I tried different setting and software. Nothing is working with me.
Can anyone help me to solve this problem?
Thank you.
vietnguyen
Re: E180 Extrusion Problems
Post by vietnguyen »
Same here
Hi,I hope this can help you: 1. Check the motor driver board voltage (0.8-1.2v);
2. Check the tightness of the belt;
3. The printing speed is too fast, which may cause this reason;
4. Check the pulleys and guide rails, and lubricate them with oil.
vietnguyen
What oil do you suggest? I have SuperLube. Will that work?
