Easy Print 3D
Easy Print 3D
Why is not the A20M in the Cofig Easy Print 3D
Re: Easy Print 3D
The answer is obvious.
This printer model is newer than the last release of this program.
I will notify the GT team of the need for an update.
Re: Easy Print 3D
Hey
Joins the request
Joins the request
Re: Easy Print 3D
I recently purchased an A20M.
I first tried the test print DOG file and it looks great.
Then I started to setup the 3D WiFi Module.
Downloaded and Installed EasyPrint 3D App on my iPhone.
Connected the 3D WiFi module to my home LAN wireless network.
3D App shows the printer is online.
but ... when I use the app to try move the printer head as a test, nothing happens.
Please help advise, how to get this working so I can control the printer and print files wirelessly.
I use a MacBook Pro and iPhone.
Thank you.
Thank you.
Re: Easy Print 3D
You should check the baud rate at first.
Try to change the baud rate to the correct value and replug the USB cables.
