a10m upgrade with MK8 Extruder Aluminum feeder Kit
k6xx1
Post by k6xx1 »
hi,
i just tried to update my a10m with the MK8 Extruder Aluminum feeder Kit, i have got one issue, the extruder is turning the wrong way, it is pushing out the filament insted of feeding it when i am trying to print.
is there any easy solution?? i tried to change the wireing but without succsess. perhaps i tried it the wrong way.
would be nice if anybody got this working and can give me an easy solution :-)
thanks
Ricky1966
Re: a10m upgrade with MK8 Extruder Aluminum feeder Kit
Post by Ricky1966 »
Hi, maybe you have mounted reversed, no problem, have you just flashed firmware? If yes, you should to change clockwise, anticlockwise rotetion of extruder in configure.h.
