A10 Old firmware version V1.0.04
GP70
Post by GP70 »
Hi everybody,
I've upgraded my A10 with firmware 1.1.8 (from Geeetech) but I would like to check some configuration differences between the stock firmware V1.0.04 and the new one: has any one the V1.0.04 source code?
Thanks in advance!
Re: A10 Old firmware version V1.0.04
The old version of A10 firmware is the V1.0.4.
But it is based on the GT2560VB board.
A10.zip
(428.8 KiB) Downloaded 413 times
GP70
Post by GP70 »
Great!!!
Thank u very mach William!
My A10 has GT2560VB so it is really what I need!
In case do you know which version of Arduino IDE is compatible to compile?
Tomyuan
Post by Tomyuan »
I've checked the fw and it should be the old version fw.
I can use the IDE 1.0.1 compline it.
GP70
Post by GP70 »
Thanks!
I will try with that version!
GP70
Post by GP70 »
Guys,
I'm back with a question about firmware 1.1.8 (and I think also the 1.1.9) which bring you back in home screen when you are in any of the menu position (Eg. to set some parameters) and you don't act on knob or button for few seconds: is there a sort of timeout? I was not able to find a #define setting to disable it...
Anyone can help?
Thanks!
GP70
Post by GP70 »
Thanks vert!
