A10 gt2560 rev b 3d touch
iherbak
Post by iherbak »
Hi!
Since days i'm trying to make the 3d touch work with my printer but no luck. So i turn to the community for help.
What i've tried so far:
- the 3d touch itself is working. I tested it with an arduino uno.
- the cables of the 3d touch are also fine (also tested the extension cable)
- Wiring is like on thingiverse, using the same pins as the Z endstop using for brown,orange and red, and the white + black on zmin pins
- The touch only makes the self test on the printer and ignoring any command issued from lcd menu or octoprint
- tried my own tailored firmware, also the one provided by vert no luck
What are not clear to me:
- why the z endstop the only one that is connected to the z max pins by default?
- in the pins.h for V3 why 11 is the servo0 pin?
- Last but not least, what am i missing?
Thanks in advance,
iherbak
iherbak
Re: A10 gt2560 rev b 3d touch
Post by iherbak »
HI!
Thanks for the suggestion.
I tried that as well but in this case the touch behaves incorrectly on my side. It has no blue lights only the red and does not respond to the commands
I'm now trying to figure out about the servo options and so on in the firmware.
