Geeetech A10M get rid off 3D touch sensor
3dralf
Post by 3dralf »
I want to disable the touch sensor.
Installed a marlin 118 without Touch
But it'll not work
EEProm deleted
Leveled with a peace of paper,
after G28 the nozzle is 8mm above the bed ?!?!?
M211 S0 - softwarendstopp disabled
leveled
G92 Z0 - Z to 0
M500 - remember this
M211 S1 - softwareendstop enabled
G1 Z10 - 10Up
G1 Z0 , will not work, Entdtop hits Z:7.98
Any hints?
3dralf
Re: Geeetech A10M get rid off 3D touch sensor
Post by 3dralf »
Tried now the 1.1.9 marlin
The problem G28 always homes about 8mm above the bed
leveled
G92 Z0 - Z to 0
G1 Z10 - 10Up
G1 Z0 works now but if
G28 then nozzle is 8mm above the Bed, Display says Z 0
Must i disconnect the ABL?
Could you attach the fw of it?
Or you can use the UBL mode for the 3dtouch then test it.
You can check the z offset at first.
The default homing of the Z axis with 3dtouch should higher than the hotbed 4~6mm.
(The distance too low may cause the 3dtouch broken)
wotor
Post by wotor »
Did you disconnect Z home end switch?
