A10M starts to print then stops and then unloads filament
danielcouey
Is there some sensor or setting that makes it do this it does it both when printing from SD card or with connected computer. i have update the firmware when i installed the Bltouch. it was printing fine did 10 prints started a big print and got to 45% done when it did this the first time. Worked another 15 minutes and did it again. Filament sensor are on and do work. it was running for 12 hours when i got to the 45%. it then somehow aborted the print so i could not finish it. and now it does the whole filament unload cycle almost immediately after starting a project then after you get it going again 5 minutes later does it again. Any help would help.
danielcouey
Re: A10M starts to print then stops and then unloads filament
i have been troubleshooting and it only happens when i have any percent on EO. if i run 100% on E1 it runs just fine.
And now I can see the E1 is pushing the E0 filment up its tube. And now I have even more questions.
