For stock Geeetech A10M which Vref Voltage is the best? I checked all all five drivers is 0.8 Volt.
Under A10 Faq i found this.
1.4 Check the voltage of the motor driver and the motor connector.
Measure the voltage of the driver board, normally the value should be 0.8V-1.2V, you can put the red probe of multimeter on the potentiometer,
						A10M Vref for Stepper driver
Re: A10M Vref for Stepper driver
If they are ok at 0.8 leave them there.
I'm assuming you've got the stock A598 drivers which are the noise ones. For those anywhere between 0.8 and 1.2 is good.
If you're experiencing issues at 0.8 try increasing to 1.2
If you have TMC2208 drivers (The quiet ones) then 0.8 is the correct value.
Thank you for Feedback
Regards
Niyoki
						Regards
Niyoki
Thank you @vert ,
I changed all A4988 Vref voltages to 1.2 Volt. Everything works smooth and not more heat than with 0.8 Volt.
Regards.
Niyoki
Regards.
Niyoki
